Wujun
6 years agoCan nPERST pins be used as PCIe reset if Intel® Stratix® 10 PCI Express* Hard IP is used as Root Complex?
Hello, According to the Pin Connection Guildline, Pin Functions of nPERST[L,R][0:2] are input or I/O. When you do not use this pin as the fundamental reset, you can use this pin as a user I/O pin. ...
- 6 years ago
Hi ,
I will share you one design , I hope it is publicly available with Root port .
Use the below as reference
Kindly have reference.
https://rocketboards.org/foswiki/Projects/Stratix10PCIeRootPortWithMSI
Wujun
6 years agoSo if I use the PCIe HIP and use S10 as Root Complex (system side), which pin can be connected to the End Point (device side) PERST#? Because as a RC, S10 need a output PCIe PERST#, but the S10 nPERST pin is an input signal.
