Can nPERST pins be used as PCIe reset if Intel® Stratix® 10 PCI Express* Hard IP is used as Root Complex?
- 6 years ago
Hi ,
I will share you one design , I hope it is publicly available with Root port .
Use the below as reference
Kindly have reference.
https://rocketboards.org/foswiki/Projects/Stratix10PCIeRootPortWithMSI
Hi ,
Sorry to keep you to wait this much long , I have done my research, kindly find the details.
When the PCIe HIP , setting is made as root port , the pin_perst configured as input , the same I have verified with Stratix 10 example design.
Kind find the attached screen shot for PCIe HIP for your reference which I took from the example design.
Hi ,
The pin_perst configured as input?
->From the screen shot, pin_perst is just an internal signal, but I need a pin name which can be found in the Intel® Stratix® 10 Device Family Pin Connection Guidelines. Do you mean when S10 is setting as root port, nPERST pin can be used and be configured as output?
