16 years ago
Buffer Overflow and Underflow in Clocked Video Input/Output
Hi
I am designing a video system to buffer three HD 1080p video stream. The input is in RGB 4:4:4 format at 148.5MHz. Output is also the same. I am using Quartus 9.0 SP1.
The system for single HD stream consists of CVI, Frame Buffer and CVO block. Three such blocks are cascaded serially. (There is a custom video processing block but it is outside the SOPC system and not yet connected to the design).
For the SOPC system, I am using 160 MHz clock. For CVI, I am using recovered clock, provided by HDMI chip. For CVO block, output clock is 148.5 MHz, which is generated by local PLL. I am also using DDR2 controller (Microtronix) running at 300 MHz in Startix-III FPGA.
I get the video output but I am also getting Underflows in the video output block and occasional overflow in the video input block. Due to these error, I get a flicker in the output. I have increased the buffer sizes in both these blocks to at lease 4K pixels. I am also using 160MHz clock for SOPC to offset the overhead of Avalon packet generation. But still cannot get rid of these Overflow and underflows. I dont know what else can I do to solve this problem. I'll be very thankful if someone can give any insight or suggestions.
Faisal
    --- Quote Start ---
    1 - Make sure your timing is properly constrained and that you are meeting timing requirements.
    2 - If I understand correctly, you've got a 64-bit DDR2 interface. How wide is the local interface with the Microtronix controller. Make sure all the memory masters on your frame buffers are set to match that width. Also, make sure your burst targets are set to at least 32.
    3 - You should get the design working with one video processing path first. Then add to it.
    Jake
    --- Quote End ---
    Hi Jake
    Yes you are right, the DDR2 has 64 DQ lines and the local interface of all the frame buffers to the DDR2 controller is 128 bit wide.
    I have set the following parameters for the all the frame buffers:
    1. Master READ/WRITE interface width: 128
    2. Master READ/WRITE FIFO Depth: 1024
    3. Master READ/WRITE Burst Target: 128
    The Microtronix DDR2 controller has 2 settings for each port, which is fifo depth and burst length. I have set them to be 512 each. Do you think that the burst length should be less than FIFO depth?
    You said that "you should get the design working with one video processing path first. then add to it".
    I assume that by video processing path you mean CVI and CVO blocks (excluding frame buffers). Can I directly connect these two? I previously tried that but it did not worked. I read in some thread here that it might not work. However I can just put in a scaler with scaling factor of 1 just to delay the data. I hope it wont create any timing violations.
    Faisal
    You may be causing yourself problems having that burst length of 128. With a pixel width of 24 that means 5 pixels to every write/read. That means that each memory master is going to try and write/read 640 pixels each burst. I'd have to do the math but with all your masters writing/reading you may be temporarily starving the CVI and CVO. Try reducing the burst size to 32.
    Your original post said you had 3 paths (3xCVI->3xBuffer->3xCVO). Get one path working first.
    Also, set your frame buffers to triple buffering until you get things working.
    Jake
    --- Quote Start ---
    Jake
    --- Quote End ---
    Hi Jake
    Thanks for help.
    There are some other parameters I am not very clear about. As I am having underflow in the video output module. There is a parameter setting in CVO in SOPC. It is "FIFO level at which to start output". By default this is set to zero. Can my underflow be caused by this setting? Should I set to some other value like 32 or 64? (I have set FIFO size in CVO to be 4096 pixels).
    Second parameter is also related to CVO and it is "active picture line". Is it the line number from which CVO starts to output a frame or it is total number of lines? I have currently set it to 1080. (I am designing for 1080p60 video).
    I'll be thankful for your help.
    Faisal
    > I have set FIFO size in CVO to be 4096 pixels.
    You should set "FIFO level at which to start output" to something close to that value (for instance 4000 or more). Throughput "burstiness" may cause underflow.
    Hi all, i am stillan FPGA noob and i have a similar problem, and it is about bandwidth calculations but using a SDR sdram.
    I hope someone could help me.
    My video input into the deinterlacer and the framebuffer are respectively 320*240i (5 bits per color plane) and 320*240p(5 bits per color plane).
    Deinterlacer performs only bob with no buffering, and frame buffer performs triple buffering.
    My SDR SDRAM controller settings are clock 100MHz, word width 16bits, fifos 64 bits and burst target 16 bits.
    color planes are in parallel, and I've calculated that i need a bandwidth of
    320*240*15(pixels)*50(fps)*6(a read master and a write master for each buffer)= 345.6mb\s
    while my available bandwidth is 16bits*100MHz= 1.6gb/s
    I set my avalon MM masters port width to 16, fifo depth to 64 and interface burst target to 16 both for write only and read only masters interface.
    CVI fifo is set to 720, cvo to 640, but the entire system doesn't work properly, I still have an input overfolw.
    I think the problem could be accord to bandwidth calculations.. or the settings for the memory mapped itnerfaces are wrong..
    I REALLY don't know how to handle all this, any hint would be precious.
    One last consideration: at the end off all, BEFORE the frame buffer,i have a Scaler.
    Maybe it is it that stalls my video flow?
    best regards
    Phate
    Hi Faisal,
    In one of the first replies, vgs mentioned the fact that the CVO clock needs to be derived form the CVI clock and if it is not, you need to use tripple buffering with frame dropping / repeating enabled. I did not see any reply indicating if you have tripple buffering enable. If the output clock (driving the CVO) is not derived from the video input clock, the output frame rate will never match the input frame rate and you will get underflows / overflows no matter how large you make the FIFOs. If you cannot derive the output clock from the input clock you have to periodically drop or repeat a frame (as would be done by a tripple buffer).
    From your diagram it looks as if only the first CVI gets the actual video input clock and all subsequent CVI and CVO gets clocked by your local 148.5MHz. As a test, just enable tripple buffering and frame dropping / repeating on you first framebuffer. If this makes the problem go away, then you know it is due to the different clocks.
    Niki
    Just one more question.
    I look at the an427 provided by altera, but I want to make a system a little different (as I've said in lots of other threads).
    In order to use rescalers or clippers instead of buffered deiterlacers, wich shuold be a "fast enough" clock for the video system?
    using a 100 MHz clock, i still have overflow in video input, no matter of how deep I set the DVI FIFO...
