16 years agoBuffer Overflow and Underflow in Clocked Video Input/Output
Hi I am designing a video system to buffer three HD 1080p video stream. The input is in RGB 4:4:4 format at 148.5MHz. Output is also the same. I am using Quartus 9.0 SP1. The system for ...
16 years ago --- Quote Start --- 1 - Make sure your timing is properly constrained and that you are meeting timing requirements. 2 - If I understand correctly, you've got a 64-bit DDR2 interface. How wide is the local interface with the Microtronix controller. Make sure all the memory masters on your frame buffers are set to match that width. Also, make sure your burst targets are set to at least 32. 3 - You should get the design working with one video processing path first. Then add to it. Jake --- Quote End --- Hi Jake Yes you are right, the DDR2 has 64 DQ lines and the local interface of all the frame buffers to the DDR2 controller is 128 bit wide. I have set the following parameters for the all the frame buffers: 1. Master READ/WRITE interface width: 128 2. Master READ/WRITE FIFO Depth: 1024 3. Master READ/WRITE Burst Target: 128 The Microtronix DDR2 controller has 2 settings for each port, which is fifo depth and burst length. I have set them to be 512 each. Do you think that the burst length should be less than FIFO depth? You said that "you should get the design working with one video processing path first. then add to it". I assume that by video processing path you mean CVI and CVO blocks (excluding frame buffers). Can I directly connect these two? I previously tried that but it did not worked. I read in some thread here that it might not work. However I can just put in a scaler with scaling factor of 1 just to delay the data. I hope it wont create any timing violations. Regards Faisal
