16 years agoBuffer Overflow and Underflow in Clocked Video Input/Output
Hi I am designing a video system to buffer three HD 1080p video stream. The input is in RGB 4:4:4 format at 148.5MHz. Output is also the same. I am using Quartus 9.0 SP1. The system for ...
16 years agoJust one more question.
I look at the an427 provided by altera, but I want to make a system a little different (as I've said in lots of other threads). In order to use rescalers or clippers instead of buffered deiterlacers, wich shuold be a "fast enough" clock for the video system? using a 100 MHz clock, i still have overflow in video input, no matter of how deep I set the DVI FIFO...
