16 years ago
Altera FFT - output scaling. How to do this correctly?
I do not get correct scaled results if I do everything the FFT user guide recommends.
I have instantiated a 1024 points FFT, with single output and burst architecture. The data width and twiddle factor precision is 16bits.
I input 1024 times 16bit signed integers from the ADC to the 16bit real-input of the FFT module. (The ADC has a +/-2.5V input) To the imaginary input of the FFT module I apply 16bit zeros. This should be correct, shouldn’t it? The FFT module outputs 1024 pairs of 16bit real and 16bit imaginary part.
First question: Are the real and imaginary 16bit values the mantissa in the sense of a floating point mantissa (first bit = sign, second bit = 1.digit in front of the radix point, remaining 14bits = decimal places) OR do I have to interpret these values as fixed point values.
I have a sample frequency of 3kHz and used a very low frequency of 1Hz and 9Hz to verify the scaling to not have additional falsifications, caused by the rectangular window I used for the first shot. I input samples of an ideal sine waveform with different amplitudes and the same frequency, BUT whether I scale the output back with the given exponent value or not, the calculated magnitude is not the expected one. For example:
For a 9Hz sine with an amplitude of +/-2,3V which is equal to +30146/-30147 decimal (+/-2.5V ADC input) I got the following real and imaginary parts for the corresponding frequency.
Real: 3384 (0x0D38)
Imaginary: -14391 (0xC7C9)
I would expect a magnitude in the range of 30146 decimal, but using these values the magnitude is 14783. Using the exponent makes the results too big and I see no relation to input signal with such big numbers. How can such a large output (31bits in my case, max exponent = 15bits) provide unity gain, if the input is much smaller (16bits). Just choosing the lower 16bits of the shifted/scaled values can not be correct, because of the sign. I am a bit confused.
Can somebody give me a hint? An example calcualtion would also be a great help.
