17 years agoAltera FFT - output scaling. How to do this correctly?
Hi, I do not get correct scaled results if I do everything the FFT user guide recommends. I have instantiated a 1024 points FFT, with single output and burst architecture. The data width...
17 years ago --- Quote Start --- The maximum |magnitude| of your input(if you think of it as complex) is the amplitude of your sinusoid. your output(y): y is complex i.e. (y= complex(yreal, yimag)) and both elements together determine amplitude and phase(abs(y),angle(y)) in frequency domain. --- Quote End --- That's exactly what I mean and that's how I learned/understood it. Ok I understood everthing correct, the input signal seems to be correct (you also looked at it), and the simulation outputs the same results as real module. Than there must be some problem with the IP-core. I opened a service request. Maybe this will result in a solution of the problem. So far I'm using my workaround with the additional shifting by 9.
