17 years agoAltera FFT - output scaling. How to do this correctly?
Hi, I do not get correct scaled results if I do everything the FFT user guide recommends. I have instantiated a 1024 points FFT, with single output and burst architecture. The data width...
17 years agoYou siad your inputis 30146, I assume you checked that in signaltap.
This matlab code can be used as reference: % generate a sinusoid at 9Hz, Fs at 3Khz x = round(30146*cos(2*pi*[0:1023]*9/3000)); % fft scaled for unity gain y = 1/512*fft(x); plot(abs(y)); max(abs(y))
