17 years agoAltera FFT - output scaling. How to do this correctly?
Hi, I do not get correct scaled results if I do everything the FFT user guide recommends. I have instantiated a 1024 points FFT, with single output and burst architecture. The data width...
17 years agoI should add, that I have monitored the exponent output of the FFT IP-core. The value I read is correct.
Then the question raises: Is the input correct?
