drbarryh's avatar
drbarryh
1 year ago
ALT PLL GUI MESSDED UP ON INVOCATION
Hi All ALTERA Experts,
I have a problem setting up a new PLL due to the GUI looking like the mess you can see in my attached screenshot. I am using Quartus Standard edition Version 25.1 I am on a windows 10 machine and all of the other IP GUIs seem to work fine, its just this PLL IP GUI that seems to get messed up.
I am using a MAX10 FPGA.
Both my PC and Graphics card are working fine. Can anybody suggest why this occurs ?
Thanks, Barry
  • FvM's avatar
    FvM
    Hi Barry, good question. May be a side effect of updated GUI library or something similar. Doubt that every software function including all Megawizard dialogs undergoes a regression test.
    • drbarryh's avatar
      drbarryh
      Hi Richard,
      Thanks for the link to a patch ....does this solve the problem on windows machines ....such as Windows 10 / 11 ?
      Also do you need a patch for L:inux (UBUNUT) as well ?
      Cheers, Dr Barry H
      • RichardT_altera's avatar
        RichardT_altera
        Yes, the patch 25.1std will solve the problem for Windows. Please try to install and let me know how it goes.
        We don't see issue with Linux so the patch is likely not required. Though the fix/patch will be implemented in the future Quartus release.
        Richard Tan
  • BCuze's avatar
    BCuze
    YES ! Thanks : I confirm that the patch does solve this issue (I tested the Windows patch).
    In my case, I had a crash, then a messed up window when I tried again
    Those who like me practiced Quartus since it did exist know this PLL GUI is jinxed :-)
    Bert
      RichardT_altera
      Thank you for confirming that the patch works.
      Do you have any other issues with the Quartus crash? Is it related to the ALTPLL GUI, or is it a completely new issue?
      Richard Tan
      • BCuze's avatar
        BCuze
        Hi Richards,
        No, it was the 1st time that I opened the PLL that the GUI just crashed, it didn't happened after the patch.
        BTW : I tried to submit a SR about the Questa license generation (Are you aware of the that ?) but the Intel report system ended up with an "Error" pop up. So I think I'll wait until this migrates to Altera before attempting SRs.
        Thanks for your kind support :-)
        Bert
  • sstrell's avatar
    sstrell
    Weird.  If you move the parameter editor window around, does it change or does it just keep looking like that?  Have you tried a lower resolution for your monitor?  The Megawizard is really old and maybe doesn't like a 4K display resolution.
    • drbarryh's avatar
      drbarryh
      Hi sstrell, i tried many Graphics card configurations, down to very low res, but nothing works i still see the same messed up GUI for that ALT_PLL IP. All other IP GUIs i have seen so far are fine, its just that one messes up. Strange! I even tried uninstalling and reinstalling QUARTUS Standard edition 25.1 but still i see that messed up GUI for ALT_PLL.
      Have you got any other suggestions ? Its a bit inconvenient NOT being able to configure a clock PLL!
      Thanks, Barry
    RichardT_altera
    I’m seeing the same issue, and I’ll report it to the tool specialists for further investigation. This problem seems to affect the ALTPLL IP across different devices (MAX 10 and Cyclone IV).
    Workaround:
    Please use an earlier version of Quartus to instantiate the IP, then upgrade the design to Quartus 25.1 Standard Edition on Windows OS.
    Alternatively, the IP instantiation GUI works correctly on Linux OS using Quartus v25.1std(tested with SUSE).
    For reference, I’ve tested this using Quartus 23.1 Standard Edition on Windows 11, and it works as expected.
    Richard Tan
    • bkantor's avatar
      bkantor
      Hi Richard,
      First thank you for confirming the issue.  I'm glad it has been noted, but I don't think it's isolated to release 25.1.  Perhaps it's bad luck, but I have not been able to get reliable operation with it for a Max 10M08SAE in Quartus 17.1, 23.1 or 25.1.  I've tried two different systems... 1x AMD, 1x Intel, both running Windows 11 with 4k monitors.  The behavior changes between releases, but every instance involves a scrambling of the screen due to GUI sizing and overlayed text.  Unlike 25.1, 23.1 was marginally readable.
      I did read about issues with high-resolution displays which lead me to testing the compatibility settings and hi-res override modes.  This leads me to the reason I believe the issue has been there awhile... the graphics compatibility settings changes the Megafunction behavior.  In some modes it refused to open, while in others it would open and crash.  The only setting that allowed it to open was no setting.  There isn't a great reason why changing this should cause such a dramatic shift in behavior.
      I would appreciate it if Altera could post an app note on how to instantiate a basic PLL without the Megafunction... a bare minimum implementation (1 clock in, 1 clock out).  I don't mind configuring a slew of parameters, I just want something that works and I can modify without worrying about the software version I have installed or having to jump between versions.
      Thanks!
      • FvM's avatar
        FvM
        VHDL example, inclock 16 MHz, outclock 50 MHz
        library ieee;
        use ieee.std_logic_1164.all;
        entity plltest_min is
            port
                inclk0  : in std_logic  := '0';
                c0      : out std_logic
        END plltest_min;
        architecture inst of plltest_min is
        component altpll
            generic
                bandwidth_type           : string;
                clk0_divide_by           : natural;
                clk0_duty_cycle          : natural;
                clk0_multiply_by         : natural;
                clk0_phase_shift         : string;
                inclk0_input_frequency   : natural;
                operation_mode           : string;
                pll_type                 : string;
                compensate_clock         : string := "CLK0";
                self_reset_on_loss_lock  : string
            port
                inclk     : in std_logic_vector (0 downto 0) := (others => '0');
                areset    : in std_logic := '0';
                clk       : out std_logic_vector (0 downto 0);
                locked    : out std_logic
            end component;
        begin
            mypll : altpll
            generic map (
                bandwidth_type => "AUTO",
                clk0_divide_by => 16,
                clk0_duty_cycle => 50,
                clk0_multiply_by => 50,
                clk0_phase_shift => "0",
                inclk0_input_frequency => 62500,  -- 16 MHz
                operation_mode => "NORMAL",
                pll_type => "AUTO",
              self_reset_on_loss_lock => "ON"
            port map (
                inclk(0) => inclk0,
                clk(0) => c0
        end inst;
        Verilog example
        module vpll_min (
        	inclk0,
        	c0);
        	input	  inclk0;
        	output	c0;
        	wire [4:0] clk;
           assign c0 = clk[0];
        	altpll	altpll_component (
        				.areset (1'b0),
        				.inclk ({1'b0, inclk0}),
        				.locked (),
        				.clk (clk));
        	defparam
        		altpll_component.bandwidth_type = "AUTO",
        		altpll_component.clk0_divide_by = 16,
        		altpll_component.clk0_duty_cycle = 50,
        		altpll_component.clk0_multiply_by = 50,
        		altpll_component.compensate_clock = "CLK0",
        		altpll_component.inclk0_input_frequency = 62500,
        		altpll_component.operation_mode = "NORMAL",
        		altpll_component.pll_type = "AUTO",
        		altpll_component.self_reset_on_loss_lock = "OFF",
        		altpll_component.width_clock = 5;
        endmodule
        Frank
    • drbarryh's avatar
      drbarryh
      Hi Richard, thanks very much for trying this out and presenting me with a solution! I will install Quartus 24.1 standard edition and see if i can generate the ALT PLL IP in that version. As you say i could then add that IP to my 25.1 project and try to upgrade it. OR would it be better option to use 24.1 Standard edition. Do you think that might be more stable for MAX10 devices ?
      I have had a lot of trouble trying to install QUARTUS standard edition 25.1 on UBUNTU 24.04 LTS. In fact its just fails miserably and i am not able to run Quartus at all even after the installer says it has installed Quartus 25.1 successfully! It hadn't.... that is another of my active threads how to resolve that problem. Maybe again i will try 24.1 and that might be OK? What a pain though .... the docs say UBUNTU 24.04 LTS is a supported OS....but not for me so far !!
      Barry
  • FvM's avatar
    FvM
    I can confirm that the corrupted display occurs with altpll (Cyclone IV and 10 LP), not altera_pll (Cyclone V) Megawizard in recent Quartus 25.1 std. Previous 24.1 std is o.k.
    You can basically use any Quartus version with full MAX10 support, e.g. starting with 19.1.
    Frank
    • drbarryh's avatar
      drbarryh
      Hi Frank, Thanks for the information. I am trying Quartus Standard 24.1 next ! But i wonder "How did that horribly messed up ALT PLL IP get through ALTERA Quality control" ? Something went amiss there i guess :)
  • BCuze's avatar
    BCuze
    This is very irritating and annoying !
    It's an old bug that keeps resurfacing (on odd years ??)
    It also hits Cyclone IV PLL (not a big surprise). And probably Cyclone 10LP too.
    Please Altera : fix this one once for good and make sure the next version will not break again.
Recent Discussions
