NBurt's avatar
NBurt
7 years ago
What is the initial state of MAX II devices pre-programming?
What is the initial state of the EPM1270F256I5 before the first programming? I'm trying to determine how to bias it.
    • NBurt's avatar
      NBurt
      So are they I/O pins or GCLK pins at default? Remember, I'm not programming my part.
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    Hi Noah,
    By default, both the pin are I/O pin. You will need to set them in Quartus if you want to have dev_clrn and dev_oe feature enabled.
    So, I/O pin will be in tri-stated. For unused pin, which you do not configure anything on the pin, by default is in tri-state mode. However, it can be changed depending on your Quartus design. To check your unused pin state in user-mode, kindly go to:
    Assignment -> Device -> Device Pin & Options -> Unused Pin
    YL
    • NBurt's avatar
      NBurt
      Hi YL,
      Thanks, that's helpful. So to clarify, what you're saying is that:
      • The IO/DEV_CLRn and IO/DEV_OE dual purpose pins by default will be in IO mode.
      • All IO pins are always in tri-state mode during power-on.
      • Unless I configure the IO pins differently, all will be in tri-state mode once the device has reached user mode.
      Does that sound accurate? Also, would you say that the IO/GCLKx pins are also in IO mode by default?
      Noah
  • NBurt's avatar
    NBurt
    Hi YL,
    I'm asking because my intent is to perform environmental testing with simple biasing for my organization. Due to time/money constraint, I won't be programming the PLD before or during testing.
    The reason I ask about the DEV_CLRn and DEV_OE pins is that they both have alternate modes as I/O pins. Without any programming, will pins M8 and M9 (for the FBGA-256 package) be in DEV_OE and DEV_CLRn modes respectively? Or will they be in the I/O mode?
    Noah
    • NBurt's avatar
      NBurt
      To clarify, I'm wondering what the state of those two pins will be in in User-Mode Operation if during t_CONFIG, the CPLD isn't configured.
  • NBurt's avatar
    NBurt
    Hi YL,
    To clarify, do the I/O pins STAY in tri-state after power-up (but pre-programming)?
    Also, what state are the DEV_OE and DEV_CLRn pins in after power-up (but pre-programming)?
    Noah
    YuanLi_S_Intel
    Hi Noah,
    MAX II is having hot socketing feature in which you can drive the device during power up or power down. Meanwhile the IO is in tri-state state during device power on.
    YL
