NBurt
7 years agoWhat is the initial state of MAX II devices pre-programming?
What is the initial state of the EPM1270F256I5 before the first programming? I'm trying to determine how to bias it.
YuanLi_S_Intel
7 years agoHi Noah,
By default, both the pin are I/O pin. You will need to set them in Quartus if you want to have dev_clrn and dev_oe feature enabled.
So, I/O pin will be in tri-stated. For unused pin, which you do not configure anything on the pin, by default is in tri-state mode. However, it can be changed depending on your Quartus design. To check your unused pin state in user-mode, kindly go to:
Assignment -> Device -> Device Pin & Options -> Unused Pin
YL
- NBurt7 years ago
Hi YL,
Thanks, that's helpful. So to clarify, what you're saying is that:
- The IO/DEV_CLRn and IO/DEV_OE dual purpose pins by default will be in IO mode.
- All IO pins are always in tri-state mode during power-on.
- Unless I configure the IO pins differently, all will be in tri-state mode once the device has reached user mode.
Does that sound accurate? Also, would you say that the IO/GCLKx pins are also in IO mode by default?
Noah
