15 years agoVHDL newbie : configuration file does not compile
Hi !
I wrote a VHDL snippet to test "configuration" VHDL clause (see attached project). The top level design is configExample.vhd. I've got this error : Error (10467): VHDL Component Configuration or Component Instantiation Statement error at configExampleConfig.vhd(30): component "counter4Bits" is used but not declared Whatever hard I try, I cannot get rid of it ! May I ask you some hints please ? cheers ! Sylvain8 Replies
Hi mmTsuchi !
I went through http://amouf.chez.com/syntaxe.htm#component but I still don't detect any mistake in my code... Cheers ! Sylvain - Altera_Forum
Hi Tricky !
I think it's a good way to centralize both the design description and the architecture choices for each component used in a single file. Then, a new programmer participating to the project after its beginning can refer to this file to get an accurate view of the whole system. Cheers ! Sylvain - Altera_Forum
Hi FvM !
Modelsim raises the same error report ! Cheers ! Sylvain - Altera_Forum
--- Quote Start --- Configurations are rarely used in VHDL. --- Quote End --- Nevertheless they are supported by Quartus. I've used them with an existing design. I guess, there's a syntax error in the above component configuration declaration, but I'm not aware of the syntax details. Also a limitation of the Quartus configuration feature may exist. Diy you try to compile the code with a different tool, e.g. Modelsim? - Altera_Forum
Configurations are rarely used in VHDL. There is no need to use them when you have a single architecture for an entity. And even when you have multiple architectures, there are ways you can select which one to use without having to resort to configurations.
eg. using direct instantiation
With direct instantiation, its also possible to completly avoid component declarations as well. Is there any reason you are using components?my_inst : entity my_lib.some_entity(synth_arch) generic map ( ... ) port map ( ... ); - Altera_Forum
Hi, look at http://amouf.chez.com/syntaxe.htm#component
I don't know COMPONENT and CONFIGURATION in VHDL. I couldn't help you but I will look at this thread later. It is surely interesting ! i have spent 7 years in writing vhdl without using component and configuration (except some altera's components). - Altera_Forum
Dear mmTsuchi,
Many thanks for your answer. However, it still does'nt compile, I get this message :
May I ask you some hints anew (attached sources with modification you suggested) ? Cheers ! SylvainInfo: Found 2 design units, including 1 entities, in source file src/counter4bits.vhd Info: Found design unit 1: counter4Bits-behavioural Info: Found entity 1: counter4Bits Info: Found 2 design units, including 1 entities, in source file src/configexample.vhd Info: Found design unit 1: configExample-configExampleArchi Info: Found entity 1: configExample Info: Found 2 design units, including 1 entities, in source file src/genericcounter.vhd Info: Found design unit 1: genericCounter-behavioural Info: Found entity 1: genericCounter Info: Found 1 design units, including 0 entities, in source file src/configexampleconfig.vhd Info: Found design unit 1: configExample_conf Info: Found 2 design units, including 0 entities, in source file src/configexample_pkg.vhd Info: Found design unit 1: configExample_Pkg Info: Found design unit 2: configExample_Pkg-body Error (10467): VHDL Component Configuration or Component Instantiation Statement error at configExampleConfig.vhd(30): component "counter4Bits" is used but not declared - Altera_Forum
In your configExampleConfig.vhd, use work.all your configExample_Pkg doesn't declare counter4bits. Be careful with
First, They are NOT all IEEE standards (, Second, 'Unsigned' is always defined in STD_LOGIC_ARITH Third, I uselibrary IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL;
Look at http://www.alteraforum.com/forum/showpost.php?p=112092&postcount=10 May it help you.LIBRARY ieee; USE ieee.STD_LOGIC_1164.all; USE ieee.numeric_std.all;
