15 years agoVHDL newbie : configuration file does not compile
Hi ! I wrote a VHDL snippet to test "configuration" VHDL clause (see attached project). The top level design is configExample.vhd. I've got this error : Error (10467): VHDL Component C...
15 years ago --- Quote Start --- Configurations are rarely used in VHDL. --- Quote End --- Nevertheless they are supported by Quartus. I've used them with an existing design. I guess, there's a syntax error in the above component configuration declaration, but I'm not aware of the syntax details. Also a limitation of the Quartus configuration feature may exist. Diy you try to compile the code with a different tool, e.g. Modelsim?
