15 years agoVHDL newbie : configuration file does not compile
Hi ! I wrote a VHDL snippet to test "configuration" VHDL clause (see attached project). The top level design is configExample.vhd. I've got this error : Error (10467): VHDL Component C...
15 years agoDear mmTsuchi,
Many thanks for your answer. However, it still does'nt compile, I get this message :Info: Found 2 design units, including 1 entities, in source file src/counter4bits.vhd
Info: Found design unit 1: counter4Bits-behavioural
Info: Found entity 1: counter4Bits
Info: Found 2 design units, including 1 entities, in source file src/configexample.vhd
Info: Found design unit 1: configExample-configExampleArchi
Info: Found entity 1: configExample
Info: Found 2 design units, including 1 entities, in source file src/genericcounter.vhd
Info: Found design unit 1: genericCounter-behavioural
Info: Found entity 1: genericCounter
Info: Found 1 design units, including 0 entities, in source file src/configexampleconfig.vhd
Info: Found design unit 1: configExample_conf
Info: Found 2 design units, including 0 entities, in source file src/configexample_pkg.vhd
Info: Found design unit 1: configExample_Pkg
Info: Found design unit 2: configExample_Pkg-body
Error (10467): VHDL Component Configuration or Component Instantiation Statement error at configExampleConfig.vhd(30): component "counter4Bits" is used but not declared May I ask you some hints anew (attached sources with modification you suggested) ? Cheers ! Sylvain
