15 years agoVHDL newbie : configuration file does not compile
Hi ! I wrote a VHDL snippet to test "configuration" VHDL clause (see attached project). The top level design is configExample.vhd. I've got this error : Error (10467): VHDL Component C...
15 years agoHi,
In your configExampleConfig.vhd, use work.all your configExample_Pkg doesn't declare counter4bits. Be careful withlibrary IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL; First, They are NOT all IEEE standards (, Second, 'Unsigned' is always defined in STD_LOGIC_ARITH Third, I use LIBRARY ieee;
USE ieee.STD_LOGIC_1164.all;
USE ieee.numeric_std.all; Look at http://www.alteraforum.com/forum/showpost.php?p=112092&postcount=10 May it help you.
