[VHDL] integer to std_logic or std_logic_vector conversion
I've some issues to convert integer to std_logic or std_logic_vector. I need to do so for a testbench which reads stimuli (binary or positive integers) in a text file, stores it as integer and needs to translate it to std_logic or std_logic_vector. I can store stimuli as integer but I can't translate it to std_logic or std_logic_vector. I try first to cast them to unsigned and cast after the result to std_logic or std_logic_vector. I use the ieee.numeric_std package because I read that using the ieee.std_logic_unsigned package could lead to errors (then, i do not use the conv_std_logic_vector function). Here is an extract of my code. Please provide any advice or ideas to solve my problem.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
USE work.txt_util.all;
ENTITY read_conv IS
PORT(
clk : in std_logic;
rst_n : in std_logic;
start_in : in std_logic;
--- std_logic inputs ---
reset_hw_i : in integer;
wdogInitDelay_i : in integer;
--- std_logic outputs ---
reset_hw_o : out std_logic;
wdogInitDelay_o : out std_logic_vector(15 downto 0)
END read_conv;
ARCHITECTURE arch_read_conv OF read_conv IS
BEGIN
conv : PROCESS (clk, rst_n)
VARIABLE reset_hwVar : std_logic;
VARIABLE wdogInitDelayVar : std_logic_vector(15 downto 0);
BEGIN
if rst_n='0' then
reset_hwVar := '0';
reset_hw_o <= '0';
wdogInitDelayVar := (others=>'0');
wdogInitDelay_o <= (others=>'0');
else
-- Cast an integer to an unsigned on 1 bit and cast it again to std_logic
reset_hwVar := std_logic_vector(to_unsigned(reset_hw_i, 1));
print("Integer read : 0x" & str(reset_hw_i, 16));
print("std_logic_vector 0x" & str(reset_hwVar));
reset_hw_o <= reset_hwVar;
-- Cast an integer to an unsigned on 16 bit and cast it again to std_logic_vector
wdogInitDelayVar := std_logic_vector(to_unsigned(wdogInitDelay_i, 16));
print("Integer read : 0x" & str(wdogInitDelay_i, 16));
print("std_logic_vector 0x" & hstr(wdogInitDelayVar));
wdogInitDelay_o <= wdogInitDelayVar;
end if;
END PROCESS conv;
END arch_read_conv;
using the temporary variable should work fine. Is it because you forgot a space between downto and 0?
And in your origional post, there are no wait until statements in your code. But note that you cannot have a sensitivity list and wait statements, its one or the other. - Altera_Forum
Hello Tricky,
First, thanks for your time and interest... Next, I indeed though that
was correct. I changed it. However,signal a: std_logic_vector(0 downto 0); signal b : std_logic; b <= a;
produces an error : "Range constraint violation", whatever the value I store in my text file (0 or 1). Shouldn't I store it to a temporary value because VHDL doesn't understand the statement?reset_hwVar := to_unsigned(reset_hw_i, 1)(0);
(I tried, I've the same error) What concerns the process, indeed, It will run on every clock event... Didn't pay attention to it yet. I just put 'WAIT UNTIL' statements.VARIABLE reset_hwTemp : unsigned(0 downto0); ... reset_hwTemp:= to_unsigned(reset_hw_i, 1); reset_hwVar := reset_hwTemp(0); - Altera_Forum
Secondly, with your process, did you realise the process is going to run whenever clk changes from anything to anything? so as well as '0' to '1', it will execute from '1' to '0' too?
Looking at your code, I think you are getting a little confused. Basically, you seem to misunderstand the difference between std_logic and std_logic_vector.
A std_logic_vector is an array of std_logic. Therefore, they are NOT the same type, and you cannot assing a std_logic from a std_logic_vector, but you can assign one from an individual element of a std_logic_vector. So, in this case: signal a: std_logic_vector(0 downto 0); signal b : std_logic; you cannot do this, even though the length is only 1: b <= a; you have to do this: b <= a(0); Now, also know that unsigned and signed are also arrays of std_logic, hence why you can do a simple type conversion between them rather than need a conversion function (like to_unsigned) because they are similar type. So the problem you have is this line: reset_hwVar := std_logic_vector(to_unsigned(reset_hw_i, 1)); because reset_hwVar is a std_logic (not a vector). To solve this, all you need to do is select the 0th bit of the output of the conversion function to unsigned(because it is an array of std_logic) so you can change it to this reset_hwVar := to_unsigned(reset_hw_i, 1)(0); - Altera_Forum
You can learn a lot from this: vhdl math tricks of the trade (http://www.google.de/url?sa=t&source=web&cd=2&ved=0ccaqfjab&url=http%3a%2f%2fwww.synthworks.com%2fpapers%2fvhdl_math_tricks_mapld_2003.pdf&rct=j&q=vhdl%20tricks&ei=zkyftrx4fyzlswbwtrdhaq&usg=afqjcnec4ynse8rjf-gttoh_rkr7rqunsg&sig2=cdf886mgltevmhzwumnnfa)
Thank you for your answer...
First, the device under test needs std_logic signals as input signals, then, I'll need to convert unsigned to std_logic_vector. I tried your trick reset_hwVar := to_unsigned(reset_hw_i, 1)(0); but it doesn't work. If you've any other idea, don't hesitate... - Altera_Forum
First, you could try to work only with unsigned signals and to ban all std_logic_vector. I don't know if it's the very good idea but it works great for me. Then to create an std_logic signal, something like this should work : reset_hwVar := to_unsigned(reset_hw_i, 1)(0); - Altera_Forum
Sorry, I posted two times this thread... I though it failed at first time.
If an admin could remove the second: Ok I'can't post links... great rule! I don't find how to do it by myself...
