14 years ago[VHDL] integer to std_logic or std_logic_vector conversion
Hello, I've some issues to convert integer to std_logic or std_logic_vector. I need to do so for a testbench which reads stimuli (binary or positive integers) in a text file, stores it as intege...
14 years agoLooking at your code, I think you are getting a little confused. Basically, you seem to misunderstand the difference between std_logic and std_logic_vector.
A std_logic_vector is an array of std_logic. Therefore, they are NOT the same type, and you cannot assing a std_logic from a std_logic_vector, but you can assign one from an individual element of a std_logic_vector. So, in this case: signal a: std_logic_vector(0 downto 0); signal b : std_logic; you cannot do this, even though the length is only 1: b <= a; you have to do this: b <= a(0); Now, also know that unsigned and signed are also arrays of std_logic, hence why you can do a simple type conversion between them rather than need a conversion function (like to_unsigned) because they are similar type. So the problem you have is this line: reset_hwVar := std_logic_vector(to_unsigned(reset_hw_i, 1)); because reset_hwVar is a std_logic (not a vector). To solve this, all you need to do is select the 0th bit of the output of the conversion function to unsigned(because it is an array of std_logic) so you can change it to this reset_hwVar := to_unsigned(reset_hw_i, 1)(0);
