16 years ago
Verilog process not implemented correctly in Quartus
It seems as though the following synchronous process in Verilog is sometimes not implemented correctly by Quartus. Why?
always @(posedge clk, negedge rst_n)
if (!rst_n)
begin
hdr_frame_length_s[15:0] <= 1;
end
else if (!srst_n || sof)
begin
end
else if (valid_in)
begin
hdr_frame_length_s <= hdr_frame_length_s + 1;
end
The code above worked as intended in at least one compilation. However in at least one other compilation, sof would not reset the register.
There are two non-standard things here, first the register is reset to 1 not 0, and second the synchronous reset is a logical OR of two inputs.
Why is this code problematic to Quartus?
Thanks for you help,
Avshalom.
    --- Quote Start ---
    how the signals !srst_n and sof generated ? Outside the FPGA ?
    Kind regards
    GPK
    --- Quote End ---
    These are synchronous register outputs (synchronous to clk)
    Thanks for all your replies, I appreciate it.
    --- Quote Start ---
    What Quartus Version are you using ?
    --- Quote End ---
    9.1 sp1 build 304
    --- Quote Start ---
    if 1 compilation is working and 1 not, what about the others ?
    --- Quote End ---
    I have changed the coding to be more compliant with the recomended HDL coding guidelines, and it seems work properly for this compilation (then again it could be just a "lucky" compilation and the next one will fail again, as happened before).
    --- Quote Start ---
    one thing that i am not shure is, shouldn't you write
    always @(posedge clk or negedge rst_n)
    --- Quote End ---
    SystemVerilog
    --- Quote Start ---
    Did you specify the initial values for hdr_frame_length_s ?
    like
    reg [15:0] hdr_frame_length_s = 16'd1;
    or during
    initial
    begin
    end // of initialiser block
    --- Quote End ---
    the code is synthesizable, register is initialized @ negedge rst_n
    --- Quote Start ---
    Do you get any warnings during compilation ?
    --- Quote End ---
    Not any that seem related
    --- Quote Start ---
    if (!rst_n)
    begin
    end
    begin
    end
    else if (valid_in)
    begin
    end
    Avshalom.
    --- Quote End ---
    Kind regards
    GPK
    @ kaz
    what do you mean with "sequential last statement overwrites" ???
    still i am missing the last
    else
    hdr_frame_length_s <= hdr_frame_length_s;
    Okay that one is not realy needed, but an if has an else .. just to be sure
    like
    or during
    initial
    begin
    Have a look at this Doc Recomended HDL coding guidelines.
    http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=4&wt.oss_r=1&wt.oss=hdl design guide (http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=4&wt.oss_r=1&wt.oss=hdl design guide)
    It could be the priority logic(if else) and the fact that the sequential last statement overwrites that is causing the problem...
