16 years agoVerilog process not implemented correctly in Quartus
Hi, It seems as though the following synchronous process in Verilog is sometimes not implemented correctly by Quartus. Why? always @(posedge clk, negedge rst_n) if (!rst_n) begin ...
16 years ago --- Quote Start --- Hi, It seems as though the following synchronous process in Verilog is sometimes not implemented correctly by Quartus. Why? always @(posedge clk, negedge rst_n) if (!rst_n) begin hdr_frame_length_s[15:0] <= 1; end else if (!srst_n || sof) begin hdr_frame_length_s[15:0] <= 1; end else if (valid_in) begin hdr_frame_length_s <= hdr_frame_length_s + 1; end The code above worked as intended in at least one compilation. However in at least one other compilation, sof would not reset the register. There are two non-standard things here, first the register is reset to 1 not 0, and second the synchronous reset is a logical OR of two inputs. Why is this code problematic to Quartus? Thanks for you help, Avshalom. --- Quote End --- Hi, how the signals !srst_n and sof generated ? Outside the FPGA ? Kind regards GPK
