16 years agoVerilog process not implemented correctly in Quartus
Hi, It seems as though the following synchronous process in Verilog is sometimes not implemented correctly by Quartus. Why? always @(posedge clk, negedge rst_n) if (!rst_n) begin ...
16 years agoThanks for all your replies, I appreciate it.
--- Quote Start --- What Quartus Version are you using ? --- Quote End --- 9.1 sp1 build 304 --- Quote Start --- if 1 compilation is working and 1 not, what about the others ? --- Quote End --- I have changed the coding to be more compliant with the recomended HDL coding guidelines, and it seems work properly for this compilation (then again it could be just a "lucky" compilation and the next one will fail again, as happened before). --- Quote Start --- one thing that i am not shure is, shouldn't you write always @(posedge clk or negedge rst_n) --- Quote End --- SystemVerilog --- Quote Start --- Did you specify the initial values for hdr_frame_length_s ? like reg [15:0] hdr_frame_length_s = 16'd1; or during initial begin hdr_frame_length_s = 16'd1; end // of initialiser block --- Quote End --- the code is synthesizable, register is initialized @ negedge rst_n --- Quote Start --- Do you get any warnings during compilation ? --- Quote End --- Not any that seem related
