16 years agoVerilog process not implemented correctly in Quartus
Hi, It seems as though the following synchronous process in Verilog is sometimes not implemented correctly by Quartus. Why? always @(posedge clk, negedge rst_n) if (!rst_n) begin ...
16 years agoWhat Quartus Version are you using ?
if 1 compilation is working and 1 not, what about the others ? one thing that i am not shure is, shouldn't you write always @(posedge clk or negedge rst_n) Did you specify the initial values for hdr_frame_length_s ? like reg [15:0] hdr_frame_length_s = 16'd1; or during initial begin hdr_frame_length_s = 16'd1; end // of initialiser block Do you get any warnings during compilation ? Have a look at this Doc Recomended HDL coding guidelines. http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=4&wt.oss_r=1&wt.oss=hdl design guide (http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=4&wt.oss_r=1&wt.oss=hdl design guide)
