16 years agoTimeQuest .sdc constraints for EPCS (ALTASMI_PARALLEL megafunction)
Hi all,
I'm using the ALTASMI_PARALLEL megafunction to access a EPCS16 device at 25MHz (active serial) on a Cyclone III device. The EPCS16 is 2 centimeters away from the FPGA (very small PCB traces). In order for this to work I had to select "Use and user I/O" on all four EPCS interface pins. As a side effect I now need to properly constrain these four pins in TimeQuest. I know that the signals are "source-synchronous output" because the clk is outputted from the FPGA (AN433) but nevertheless this seams tricky because the data in using falling edge and dataout uses riding edge. Has anyone already did that ? Can you share the file ?
