16 years agoTimeQuest .sdc constraints for EPCS (ALTASMI_PARALLEL megafunction)
Hi all, I'm using the ALTASMI_PARALLEL megafunction to access a EPCS16 device at 25MHz (active serial) on a Cyclone III device. The EPCS16 is 2 centimeters away from the FPGA (very small PCB ...
16 years agoamilcar,
I think you need to use set_min_delay and set_max_delay to constrain the output clock ( ALTERA_DCLK) instead of set_max_skew
