16 years agoTimeQuest .sdc constraints for EPCS (ALTASMI_PARALLEL megafunction)
Hi all, I'm using the ALTASMI_PARALLEL megafunction to access a EPCS16 device at 25MHz (active serial) on a Cyclone III device. The EPCS16 is 2 centimeters away from the FPGA (very small PCB ...
16 years agoFor this altasmi_parallel core and the dedicated AS pins, you don't need to add any timing constraint on it, and you don't need to do timing analysis.
