TimeQuest .sdc constraints for EPCS (ALTASMI_PARALLEL megafunction)
Hi all,
I'm using the ALTASMI_PARALLEL megafunction to access a EPCS16 device at 25MHz (active serial) on a Cyclone III device. The EPCS16 is 2 centimeters away from the FPGA (very small PCB traces). In order for this to work I had to select "Use and user I/O" on all four EPCS interface pins. As a side effect I now need to properly constrain these four pins in TimeQuest. I know that the signals are "source-synchronous output" because the clk is outputted from the FPGA (AN433) but nevertheless this seams tricky because the data in using falling edge and dataout uses riding edge. Has anyone already did that ? Can you share the file ?16 Replies
--- Quote Start --- I think I've actually hit a bug related to hold timing violation of data output from the hard ASMI block to the first flip-flop in the shift register in ALTASMI_PARALLEL. The tool doesn't appear to time that path. On some builds (~1 out 20) the timing is precisely off such that there is a hold violation on that path, and I get inconsistent data on the ALTASMI_PARALLEL dataout port from one read to another. Probing internally on the FPGA with signal probe, I see that data is correct coming out of ASMI but incorrect after it is latched into the shift-register. So much for not having timing constraints :( Opening an SR with Altera. --- Quote End --- Hi, thanks for posting this here. Can you let us know what the answer from Altera was? Thanks! - Altera_Forum
So much for not having timing constraints :( Opening an SR with Altera. - Altera_Forum
--- Quote Start --- For this altasmi_parallel core and the dedicated AS pins, you don't need to add any timing constraint on it, and you don't need to do timing analysis. --- Quote End --- Hi, I've noticed that the post is a bit old, but... on what do you base your statement? Have you found this recommendation anywhere? Typicall when Altera generates some core (e.g. Nios) it will also generate a corresponding .sdc file. For ASMI I haven't seen any, so I just thought I have to constrain it, just in case... - Altera_Forum
Thanks rbugalho, I've now added those constraints (edited the original post in the previous page) and the warnings are gone.
I still use the max_skew to relate epcs_clk with the output pin of the FPGA. - Altera_Forum
amilcar,
I think you need to use set_min_delay and set_max_delay to constrain the output clock ( ALTERA_DCLK) instead of set_max_skew - Altera_Forum
I got those expressions from the TimeQuest on-line video tutorial. They might be wrong, I'm still waiting for the FAE answer, maybe he could shed some light on it.
--- Quote Start --- Did you noticed that I have a - sign before the [expr ] ? --- Quote End --- Didn't notice them, but I don't believe they should be there. You're current expressions: # Board trace delays set max_btd 2 set min_btd 1 -[expr +$min_btd +10 -$max_btd] -[ 1 + 10 - 2 ] -[ 11 - 2 ] -[ 9 ] -9 -[expr +$min_btd +5 -$max_btd] -[ 1 + 5 - 2 ] -[ 6 - 2 ] -[ 4 ] -4 What the system view, source sync docs seem to be saying (no leading minus sign on the entire expression,instead tH value itself is negated): [expr +$min_btd -10 -$max_btd] [ 1 - 10 - 2 ] [ -9 - 2 ] [ -11 ] -11 [expr +$min_btd -5 -$max_btd] [ 1 - 5 - 2 ] [ -4 - 2 ] [ -6 ] -6 The results do seem to work out differently. Tbh, I havent seen versions of these -max -min equations where the -min [expr... ] has started off with a negative sign. - Altera_Forum
one other question for you. It seems that on your output delays, you're using a system view, accounting for board data delay, setup & hold values of the external device and board clk delays. With that view of the outside world I've read that -max -min formulas look like this:
Output max delay = max(board_data_delay) + tsu_ext - min(board_clk_delay) Output min dalay = min(board_data_delay) - th_ext - max(board_clk_delay) Did you intend to have positive tH values in your assertion expressions, as shown in bold and italicized below? # Board trace delays set max_btd 2 set min_btd 1 # Set Output Delay, see Table 3-16 of the EPCS Datasheet# ************************************************* *************# Do not violate tSLCH (t ce setup) set_output_delay -add_delay -max -clock [get_clocks {clk_epcs}] [expr +$max_btd +10 -$min_btd] [get_ports {*ALTERA_SCE}]# Do not violate tCHSL (t ce hold) set_output_delay -add_delay -min -clock [get_clocks {clk_epcs}] -[expr +$min_btd +10 -$max_btd] [get_ports {*ALTERA_SCE}] # Do not violate tDVCH (t data setup) set_output_delay -add_delay -max -clock [get_clocks {clk_epcs}] [expr +$max_btd +5 -$min_btd] [get_ports {*ALTERA_SDO}]# Do not violate tCHDX (t data hold) set_output_delay -add_delay -min -clock [get_clocks {clk_epcs}] -[expr +$min_btd +5 -$max_btd] [get_ports {*ALTERA_SDO}] ***** Your setup (-max) formulas looks good. However, I'm wondering if your hold (-min) formulas are correct. Appying the system view formula from above: Output min dalay = min(board_data_delay) - th_ext - max(board_clk_delay) I thinking your output delay -min statements should look like this: set_output_delay -add_delay -min -clock [get_clocks {clk_epcs}] -[expr +$min_btd -10 -$max_btd] [get_ports {*ALTERA_SCE}] set_output_delay -add_delay -min -clock [get_clocks {clk_epcs}] -[expr +$min_btd -5 -$max_btd] [get_ports {*ALTERA_SDO}] What's your thoughts on this?
