16 years ago
Stratix III Remote Update
Hi all,
for a Stratix III design I'm trying to choose an embedded reconfiguration scheme.
Ideally I want to select a scheme where I can update the configuration device via a serial port without an additional external controller.
The Remote Update does seem to tick all the boxes but at the cost of added complexity to implement.
chapter 12. remote system upgrades with stratix iii devices shows a Nios or user designed logic oversee the reconfiguration process:
1. Is there a design example using the Nios for a SIII remote update scheme (with MCU code etc.)?
2. Is there an alternative controller function available for the SIII for Remote Update?
3. Being a novice - is the Nios its compilation tools free?
4. The Serial FLASH loader would need an external controller to program the SFL image into the FPGA before programming the configuration device with new configuration data.
The Parallel FLASH Loader megafunction seems to connect to the CPLDs JTAG port - I'd need an external controller to clock data into this port. Please suggest any arrangement that I may not have considered that wouldn't need an external controller.
