17 years agoStratix III Remote Update
Hi all, for a Stratix III design I'm trying to choose an embedded reconfiguration scheme. Ideally I want to select a scheme where I can update the configuration device via a serial port with...
17 years agoThe NIOS Embedded Design Suite comes with an IDE (Eclipse) and it uses the GNU tool chain (so yes GCC compiler). You can install the Embedded Design Suite and start using it without buying the NIOS processor. You can also use the NIOS processor in OpenCore Eval mode if you wish.
Jake
