17 years agoStratix III Remote Update
Hi all, for a Stratix III design I'm trying to choose an embedded reconfiguration scheme. Ideally I want to select a scheme where I can update the configuration device via a serial port with...
17 years agoStephen,
So from what you are describing it sounds like you are wanting to use the Active Serial configuration scheme. You will have no external controller that configures the FPGA passively. Is this correct? Jake
