17 years agoStratix III Remote Update
Hi all, for a Stratix III design I'm trying to choose an embedded reconfiguration scheme. Ideally I want to select a scheme where I can update the configuration device via a serial port with...
17 years agoLet me break this into two parts. I've used three methods for remotely updating FPGAs in the past:
1 - Use a configuration PROM which can be loaded via JTAG. This implies you have some JTAG controller in your remote system. Also, these PROM devices are not very large so really the don't accomodate Stratix III. This is passive serial or passive parallel mode. 2 - Use a CPLD in conjunction with a flash device. The CPLD handles reconfiguration of the FPGA (reads data from flash and programs FPGA). The FPGA is only responsible for requesting a reconfig from the CPLD. This mode is passive serial or passive parallel. 3 - Use a serial flash device and operate under Active Serial mode. This requires the FPGA itself to trigger and manage configurations. The only mechanism for doing this is with the Remote Update Controller as you stated. To answer your question ... yes the remote update controller is easy enough to interface to that you could write some simple verilog or VHDL code to control it. Now here is the second part: How are you going to download a new FPGA image into the flash? This has nothing to do with the remote update controller. You need some way to write to the flash device. You have to answer this question no matter what configuration scheme you choose. I have done it three ways: a - Wrote a verilog parallel flash controller to write data into the flash. The data was transferred to the board via USB. In this situation we were using a CPLD to program the FPGA from the flash in passive parallel mode. b - Used a NIOS processor to write data into the parallel flash. Again using a CPLD to configure the FPGA. Here we transferred new configuration to the data via Ethernet. c - Used a NIOS processor to write data into the EPCS serial flash device. Here we used Active Serial configuration mode in conjunction with the remote update controller. I've used both USB and Ethernet to transfer configuration data to the board under this scheme. In SoPC builder, Altera provides an EPCS controller peripheral that can be used to interface to the flash. Now for everything I've done with it, I've used the NIOS processor. But you wouldn't have to. You could certainly write a little controller to manipulate that EPCS peripheral to program your data into the flash and not use a NIOS at all. Also, Altera provides the ALTASMI_PARALLEL megafunction for programming the EPCS device. Those are the two directions I would point you in. http://www.altera.com/literature/ug/mfug_asmi.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=altasmi_parallel You can certainly do everything you need to do without a NIOS. Now when it comes to the NIOS, I'm a big proponent. You'll never get so much use out of so few logic resources as you will out of an embedded processor. I believe the price tag on the NIOS is $500.00. However, I'd just twist your sales rep's arm until he gives it to you for free.
