17 years agoStratix III Remote Update
Hi all, for a Stratix III design I'm trying to choose an embedded reconfiguration scheme. Ideally I want to select a scheme where I can update the configuration device via a serial port with...
17 years agoHi,
My name is Eldad Fragon, and I need to write a controller that will reside inside my FPGA, and upon triggeriing from an outsdie controller card will receive the bytes of the a new configuration file, and I would like to write those bytes to a paralle CFI flash(remote update function). The external controller card receives the new configuration file via a TCP/ IP protocol from an extrnal site. My FPGA is a Cyclone III device and I work in an active parallel mode to program the CFI Flash device. Is that controller doing what I described, and if can you guide me how to write this controllert that you wrote? I'd appreciate very much any information you may provide. Sincerely, Eldad Fargon [email protected]
