19 years agoStrange effect with Stratix FPGA
Hello!
I am using a Stratix EP1S10 device on a NIOS II Development Board. I use it for VHDL programming only. That means, I don't use any NIOS stuff in my project. I made my own user configuration with which I configure the FPGA. Up to now, all works fine. Now, I have implemented a shift register in my project which works fine, too. It is 850 shifts deep and shifts a 11 bit wide vector. Parallel to the shift register I implemented some logic, which examines the contents of certain shift register parts. That works fine, too, up to the moment, when the parallel logic becomes maybe too complex. Then there are strange effects on my board I can`t explain myself. For example there is a dot in the seven segment displays on my board wich is connected to the pin D19 of the FPGA, which gets active, although I never assigned the PIN D19 in the pin assignment editor. Another effect is, that the output of the FPGA is no more compatible with the output of the simulator in Quatus II, where all works as expected. When I remove some logic off the shift register, it is all right again. I know, it is hard for you to answer that, when you don't know my project, but it could be, that somone of you had similar experience (especially with the dot, which is active although it is not assigned or somethink like that), and can give me some hints, why this happens. Greets Maik
