19 years agoStrange effect with Stratix FPGA
Hello! I am using a Stratix EP1S10 device on a NIOS II Development Board. I use it for VHDL programming only. That means, I don't use any NIOS stuff in my project. I made my own user configurat...
19 years agoRemove the clock (x-tal) and you can see the difference between dynamic + static and static power consumption. Make sure the clock is realy gone by gnd-ing the input otherwise it may pickup noise instead. Datasheets tells you the static power consumption. Maybe that can give you a hint.
