19 years agoStrange effect with Stratix FPGA
Hello! I am using a Stratix EP1S10 device on a NIOS II Development Board. I use it for VHDL programming only. That means, I don't use any NIOS stuff in my project. I made my own user configurat...
19 years ago --- Quote Start --- I would set the tool for Un-used pins as inputs with Tri-state pull up. --- Quote End --- I allready did this, but this --- Quote Start --- I would see what Output pin will place that chip in turned off mode (none chip select). --- Quote End --- is a great idea. I will try this tomorrow, and see if it will work! Thanks! Maik
