12 years ago
signal power estimation
Hello guys..
I'm trying to implement a block that evaluates the signal rms value along n samples.
So, using the std definition one must do (x_k is a complex number so I have to take in account |x_k|):
http://upload.wikimedia.org/math/0/1/4/014a453df92ed77eca97b228f0624d9f.png
The simplier way I have in mind is to use an accumulator. By the way it will indroduce some overflow issues. There is a good way in doing this ??
Thank you !
    Thank you kaz.. I'm on it..
    I've written the following code:
    LIBRARY ieee;
    USE ieee.std_logic_1164.all;
    USE IEEE.std_logic_unsigned.all;
    ENTITY rms_estimator IS
        GENERIC (ACCBIT : INTEGER:=10);
        PORT( squared_abs : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
                clk , clr : IN STD_LOGIC;
                squared_rms: OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
                ready : out STD_LOGIC;
    END ENTITY rms_estimator;
    ARCHITECTURE logic OF rms_estimator IS
    signal sum : STD_LOGIC_VECTOR(ACCBIT+31 downto 0):=(OTHERS =>'0');
    signal i : STD_LOGIC_VECTOR(ACCBIT downto 0):=(OTHERS =>'0');
    BEGIN
    PROCESS(clk,clr)
       BEGIN
            IF(clr = '1') THEN
                squared_rms<=(OTHERS =>'0');
                sum<=(OTHERS =>'0');
                ready<='0';
                i<=(OTHERS =>'0');
            ELSIF rising_edge(clk) THEN
                if (i=2**ACCBIT) then
                   squared_rms<=std_logic_vector(sum(ACCBIT+31 downto ACCBIT));
                   ready<='1';
                else
                    sum<=  sum + unsigned(pad & squared_abs);
                    i<=i+1;
                    ready<='0';
                    squared_rms<=(others=>'0');
                end if;
            END IF;
        END PROCESS;
    END ARCHITECTURE logic;
    by the way the squared_rms is always at 'X' after the ready bit is set to '1'.. Any suggestions ?? I'm really stucked...
    Thank you for your time!
    some suggestions(not compiled)
    signal sum : unsigned(ACCBIT+31 downto 0):=(OTHERS =>'0');
    signal i : unsigned(ACCBIT downto 0):=(OTHERS =>'0');
    BEGIN
    PROCESS(clk,clr)
    BEGIN
    IF(clr = '1') THEN
        squared_rms <= (OTHERS =>'0');
        sum <= (OTHERS =>'0');
        ready <= '0';
        i < =(OTHERS =>'0');
        if (i=2**ACCBIT - 1) then
             sum <= (others => '0');
             ready<='1';
             i <= (others => '0');
         else
            sum<=  sum + unsigned(pad & squared_abs); -- what is pad? '0'?
            i<=i+1;
            ready<='0';
            --squared_rms<=(others=>'0'); -- you may keep it latched
         end if;
    END IF;
    END PROCESS;
    Thank you kaz..
    the 'pad' was not intended to be there it was written down in a previus attempt.
    I have not updated the 'i' signal after it equals 2**ACCBIT because for testing pourpose I want to stop the sum when the ready bit is set.
    By the way I always have XXXX... as output when the ready bit is set... mumble mumble..
    It seems that the problem is in the recursion..
    If i set:
    sum<=32767+sum ==> the rms is 32767 as expected
    try correct the width of squared_rms (should be less 10 bits).
    edit: ignore this note as it is 32 bits so is abs
    change sum type to unsigned
    Dear kaz..
    What I see is that at reset time:
    sum=0;
    Then at the first sum:
    sum<=sum+unsigned(squared_abs) --squared_abs=2147483647 loaded from a .dat file
    The result is XXXXXX and it mantains its value until the ready bit is set and de-set. After the de-setting it starts summing correctly from 0.
    Thank you !
    I've found the bug.. In the testbench i was not restting the input. Now it seems to work correctly. Thank you for the help kaz. You're a real guru !
    Hello guys..
    Now I'm working with RMS power estimation again.. I have two complex signals: sig1 and sig2.
    I measure the RMS of sig1 and sig2 with a vhdl block and then via software I calculate: [(float) RMS(sig1)] / [(float) RMS(sig2)] with sig1>sig2.
    I want that RMS(sig1) ~= RMS(sig2). So I tried to multiply sig2 with a 16-int-constant related to [(float) RMS(sig1)] / [(float) RMS(sig2)] and then take the 16-MSB after that multiplication. By the way I think I'm still missing something because I see funny results..
    Any suggestions ?
    Thank you! have a nice day !
