12 years agosignal power estimation
Hello guys.. I'm trying to implement a block that evaluates the signal rms value along n samples. So, using the std definition one must do (x_k is a complex number so I have to take in acc...
12 years agoThank you kaz.. I'm on it..
I've written the following code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE IEEE.std_logic_unsigned.all;
ENTITY rms_estimator IS
GENERIC (ACCBIT : INTEGER:=10);
PORT( squared_abs : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
clk , clr : IN STD_LOGIC;
squared_rms: OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
ready : out STD_LOGIC;
END ENTITY rms_estimator;
ARCHITECTURE logic OF rms_estimator IS
signal sum : STD_LOGIC_VECTOR(ACCBIT+31 downto 0):=(OTHERS =>'0');
signal i : STD_LOGIC_VECTOR(ACCBIT downto 0):=(OTHERS =>'0');
BEGIN
PROCESS(clk,clr)
BEGIN
IF(clr = '1') THEN
squared_rms<=(OTHERS =>'0');
sum<=(OTHERS =>'0');
ready<='0';
i<=(OTHERS =>'0');
ELSIF rising_edge(clk) THEN
if (i=2**ACCBIT) then
squared_rms<=std_logic_vector(sum(ACCBIT+31 downto ACCBIT));
ready<='1';
else
sum<= sum + unsigned(pad & squared_abs);
i<=i+1;
ready<='0';
squared_rms<=(others=>'0');
end if;
END IF;
END PROCESS;
END ARCHITECTURE logic; by the way the squared_rms is always at 'X' after the ready bit is set to '1'.. Any suggestions ?? I'm really stucked... Thank you for your time!
