12 years agosignal power estimation
Hello guys.. I'm trying to implement a block that evaluates the signal rms value along n samples. So, using the std definition one must do (x_k is a complex number so I have to take in acc...
12 years agoI've found the bug.. In the testbench i was not restting the input. Now it seems to work correctly. Thank you for the help kaz. You're a real guru !
