12 years agosignal power estimation
Hello guys.. I'm trying to implement a block that evaluates the signal rms value along n samples. So, using the std definition one must do (x_k is a complex number so I have to take in acc...
12 years agotry correct the width of squared_rms (should be less 10 bits).
edit: ignore this note as it is 32 bits so is abs change sum type to unsigned
