12 years agosignal power estimation
Hello guys.. I'm trying to implement a block that evaluates the signal rms value along n samples. So, using the std definition one must do (x_k is a complex number so I have to take in acc...
12 years agoDear kaz..
What I see is that at reset time: sum=0; Then at the first sum: sum<=sum+unsigned(squared_abs) --squared_abs=2147483647 loaded from a .dat file The result is XXXXXX and it mantains its value until the ready bit is set and de-set. After the de-setting it starts summing correctly from 0. Thank you !
