15 years ago
SDC problem
i want to implement a SoC with the maximum frequency of my board StratixIV Gx.
I used one pll with two output, first output pll.c0=150Mhz, second output is 125Mhz. After a compilation and download the program to the board, and try to execute my C code, nothing that work.
When i use the same output clock, it work correctly.
How can i resolve this problem.
    --- Quote Start ---
    Yes there are 131,072Kb implemented at this adress. it start by 00040000 and finished by 0005ffff.
    --- Quote End ---
    So what clock is used by the NIOS processor and to access that memory?
    What does the TimeQuest timing report indicate for that data path, or for the clock domain used by the processor and memory?
    Cheers,
    Dave
    --- Quote Start ---
    That range of addresses corresponds to 25952-bytes (25.24kB ).
    Is there ~32kB of memory implemented at that address?
    Cheers,
    Dave
    --- Quote End ---
    Cheers,
    Dave
    --- Quote Start ---
    So what is at that address? On-chip memory, external memory? Do you know that memory works correctly?
    If you are serious about doing FPGA development, then you need to learn to use all the tools. Modelsim is very useful for confirming that your system works, before you try to debug in hardware.
    Cheers,
    Dave
    --- Quote End ---
    The address corresponds to on chip memory. I use just on-chip memory on my design.
    For the memory worked correctly.
    --- Quote Start ---
    This the error message that appears on console
    verifying 00040000 ( 0%)
    verify failed between address 0x40000 and 0x4655f
    leaving target processor paused
    also it appear a window that contain problem occured downloading elf process failed.
    --- Quote End ---
    --- Quote Start ---
    I don't try to use a modelsim, because i don't know how can i use with nios-eclipse.
    --- Quote End ---
    Cheers,
    Dave
    --- Quote Start ---
    You can only resolve it by understanding it.
    'Nothing works' is too vague. If you said something like "Accesses to an Avalon-MM slave at address XXX from C code running on a NIOS II processor, causes the processor to lock-up (no communications) ..." that would be a little more specific.
    If you have two clocks in the system, then I you must have clock-domain crossing logic in the system to ensure valid data transfers.
    Have you tried simulating your design in Modelsim?
    Cheers,
    Dave
    --- Quote End ---
    Thank you for your reply
    Sorry, since i don't explain the problem exactly. This the error message that appears on console
    --- Quote Start ---
    --- Quote End ---
    Cheers,
    Dave
