15 years agoSDC problem
Hi, i want to implement a SoC with the maximum frequency of my board StratixIV Gx. I used one pll with two output, first output pll.c0=150Mhz, second output is 125Mhz. After a compilation and...
15 years ago --- Quote Start --- i want to implement a SoC with the maximum frequency of my board StratixIV Gx. I used one pll with two output, first output pll.c0=150Mhz, second output is 125Mhz. After a compilation and download the program to the board, and try to execute my C code, nothing that work. When i use the same output clock, it work correctly. How can i resolve this problem. --- Quote End --- You can only resolve it by understanding it. 'Nothing works' is too vague. If you said something like "Accesses to an Avalon-MM slave at address XXX from C code running on a NIOS II processor, causes the processor to lock-up (no communications) ..." that would be a little more specific. If you have two clocks in the system, then I you must have clock-domain crossing logic in the system to ensure valid data transfers. Have you tried simulating your design in Modelsim? Cheers, Dave
