scfifo-what is the problem
from this vhdl code,i make this as an avalon slave component on the cyclon2 device, and i get the output (sender) as peaks (nearly impulse) , what may be the problem?
is it something related to lpm_showahead or use_eab values,or rdrequest and wrrequest timing? library altera;use altera.altera_europa_support_lib.all;
library altera_mf;
use altera_mf.all;
library lpm;
use lpm.all;
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity tele is
port (
-- inputs:
signal address : in std_logic_vector (1 downto 0);
signal chipselect : in std_logic;
signal clk : in std_logic;
signal reset_n : in std_logic;
signal write_n : in std_logic;
signal writedata : in std_logic_vector (7 downto 0);
-- outputs:
--signal the_output : out std_logic;
signal tx_empty : out std_logic;
signal tx_full : out std_logic;
signal tx_used : out std_logic_vector (5 downto 0);
signal sender : out std_logic_vector (7 downto 0)
end entity tele;
architecture europa of tele is
component scfifo is
generic (
lpm_numwords : integer;
lpm_showahead : string;
lpm_width : integer;
lpm_widthu : integer;
overflow_checking : string;
underflow_checking : string;
use_eab : string
port (
signal full : out std_logic;
signal usedw : out std_logic_vector (5 downto 0);
signal q : out std_logic_vector (7 downto 0);
signal empty : out std_logic;
signal rdreq : in std_logic;
signal data : in std_logic_vector (7 downto 0);
signal sclr : in std_logic;
signal clock : in std_logic;
signal wrreq : in std_logic
end component scfifo;
signal wrrequest : std_logic;
signal rdrequest : std_logic;
signal sclr_me : std_logic;
begin
write_fifo : scfifo
generic map(
lpm_numwords => 64,
lpm_showahead => "off",
lpm_width => 8,
lpm_widthu => 6,
overflow_checking => "on",
underflow_checking => "on",
use_eab => "off"
port map(
clock => clk,
data => writedata,
empty => tx_empty,
full => tx_full,
q => sender,
rdreq => rdrequest,
sclr => sclr_me,
usedw => tx_used,
wrreq => wrrequest
rdrequest <='1';
sclr_me <= '0';
wrrequest <= '1';
end europa;
thanx for attention kaz,yes,thats right that reading empty or full fifo is wrong,so i make the rdrequest high when usedw signal (how many words exist in buffer) is for example 8 or 9 for a 64 byte buffer,and in vwf file the simulation is ok but when i instantiate this vhdl code in sopc and create the system, i get those periodic impulses on oscilloscope instead of the 1 bits.
i will also try to see the results in signaltap as you suggest. - Altera_Forum
Your last code still doesn't tell me about state of fifo rd/wr itself.
However, you should avoid reading empty fifo at start or full fifo. you better use SignalTap to make your study instead of scope. go to files > new > stp(signaltap) > enter your clk in the clk entry and enter your nodes, recompile and see. it needs usb blaster connected. I don't foresee any problems with altera scfifo. You better wait for few bytes then start reading. - Altera_Forum
yes,kaz that is right but here i m trying to see that the output of the fifo is electrically and logically right,i tried meaningful fifo usage also like :
process(clk,reset_n) begin if reset_n=0 then sender <="00000000"; elsif clk'event and clk='1' and full = '1' then sender_out <= sender; end if; something like that but the result was same that i see the output pins' voltages very strange like impulses. for example i write 0xa5 continuosuly,i look @ the pins of the output sender from oscilloscope and see the 1 bits and 0 bits @ right pins but 1 bits are electrically strange,that is they are not a step like function but like periodic impulses is it something about the concurrency problem of the rdrequest and wrrequest signals? - Altera_Forum
There is no functional purpose in using a fifo if you write and read data together at the same rate.
