17 years agoscfifo-what is the problem
from this vhdl code,i make this as an avalon slave component on the cyclon2 device, and i get the output (sender) as peaks (nearly impulse) , what may be the problem? is it something related to lp...
17 years agoHi,
There is no functional purpose in using a fifo if you write and read data together at the same rate.
