17 years agoscfifo-what is the problem
from this vhdl code,i make this as an avalon slave component on the cyclon2 device, and i get the output (sender) as peaks (nearly impulse) , what may be the problem? is it something related to lp...
17 years agoYour last code still doesn't tell me about state of fifo rd/wr itself.
However, you should avoid reading empty fifo at start or full fifo. you better use SignalTap to make your study instead of scope. go to files > new > stp(signaltap) > enter your clk in the clk entry and enter your nodes, recompile and see. it needs usb blaster connected. I don't foresee any problems with altera scfifo. You better wait for few bytes then start reading.
