Scaling core clock of 100MHz to 23MHz & 20MHz
Hello All,
I am using Altera Stratix II for my project. I have generated a PLL in LVDs mode(for a deserialization factor of 10 and date rates is 1000Mbps). The two available clock sources on the board are 100MHz and 62.5MHz. I need to generate 23MHz and 20MHz MHz clocks for a module in my project. When I try to generate a PLL in LVDs mode in Mega Core Wizard, by default it selects a FAST PLL and the minimum output frequency is 33.3333MHz. Can I use any other logic and generate a 23MHz and 20MHz clock from 100MHz core clock. Can any one of you suggest a solution to this problem. Many thanks in advance,34 Replies
Your logic apparently drives out a square wave to rx_channel_data_align. This can't work, cause it leaves no time for the updated result to propagate to rx_out, as I mentioned previously. I'm allowing a new data_align pulse after 8 clocks, as you can see from my example code. To evaluate DPA operation, it may be meaningful to apply a single pulse only and observe the results in simulator or SignalTap.
I tried with following code to align the word but its not working. I have taken "ready" signal to increment the address of the ram. Could you suggest any modifications?
Data_align : process (iRxClk,inUserReset) -- variable count: integer:=1; begin if(inUserReset='0') then rx_channel_data_align <= "0"; elsif(iRxClk'event and iRxClk='1') then if (rx_channel_data_align = "1") then rx_channel_data_align <= "0"; end if; if(rx_dpa_locked="1") then if (rx_out = "0100110101") then rx_channel_data_align <= "0"; ready<='1'; else rx_channel_data_align <= "1"; end if; end if; end if; end process Data_align; - Altera_Forum
As far as I experienced, ModelSim simulation of LVDS receivers and DPA was almost matching the real chip behaviour.
I understand that you are particularly referring to the word boundary integrity problem discussed in the manual. To my opinion, the issue only occurs if the correct alignment position is near to the initial position. In this case, some channels may need zero alignment pulses and some channel would need -1 pulse. Cause no negative shift is possible, these channel's phase is advanced by n-1 bit positions (n is the deserialization factor), crossing the word boundary. If the typical aligned phase is in the middle of DPA range, this never happens. So I don't think that it's necessary to check the word integrity in the DPA logic, which could be done e.g. by using a two word (alternating) train pattern. - Altera_Forum
Hiii!!1
The problem I have is clearly mentioned in page 17–12 and 17 -13 for the Stratix GX (please find below) document..... Thku very much... The only solution is to use a State Machine as mentioned by u in ur previous reply. Thku once again. So nice of u. http://www.altera.com/literature/hb/sgx/sgx_sgx52013.pdf lg, Sa - Altera_Forum
Does the DPA block behave the same in ModelSim, I mean i have introduced a transportation delay in my system and now i am trying to adjust DPA block and want to check how it actually behaves. I shall try to implement some statemachine concept as suggested by you. But, would it be possible for me to notice the chages in ModelSim before going on to the real hardware?
Yes, the DPA control should use 100 MHz (or slower) in this case.
I just was aware, that my design is actually 4 modules x 8 LVDS channels x 4 bit deserialization factor. The train can be done separately for each of the 4 modules, DPA control within a train sequence is also separate for each LVDS channel. You should analyze the logic for one channel first, it's much more simple of course. The important thing is to assure, that the sender is actually transmitting the train pattern while DPA train is activated (for 256 clocks in my design). - Altera_Forum
cant really understand :(.
Thku.. i shall try to analyse it. Well I am currently using slow clk of 100MHz on the receiver side User application. For serial transmission i am using 1000MHz clk. Boz i am using a deserilization factor of 10.
It's not part of the MegaCore, it's a user design. If I remember right, there have been also Altera design examples with DPA, but I don't remember where I had seen them.
It's not particularly necessary to enable rx_outclock, but I wonder which clock you are using to process your received data. I give you my code as is. It's for a 4x4 multichannel LVDS revceiver. As an additional hint, the dpa_reset[1:4] signal is used as start trigger for train sequence, it is generated by another design component communicating with LVDS sender. 4'h3 is the respective train pattern.always @ (posedge RESET or posedge rx_outclock_sig) begin if (RESET) begin train_timer <= 8'hff; train <= 0; rx_dpa_locked_v <= 0; ModulFehler <= 4'hf; end else begin if (dpa_reset) begin train_timer <= 0; train <= dpa_reset; rx_dpa_locked_v <= 0; end else begin case (train_timer) 255: begin train <= 0; rx_channel_data_align_sig <= 0; for (N=1;N<=4;N=N+1) if (train) begin ModulFehler = 0; for (M=8*N-8;M<8*N;M=M+1) if (!rx_dpa_locked_sig || rx_cda_max_sig) begin ModulFehler = 1; end end end default: begin for (N=1;N<=4;N=N+1) for (M=8*N-8;M<8*N;M=M+1) if (train) begin if ((train_timer % 8) == 7 && rx_dpa_locked_sig) rx_dpa_locked_v <= 1; if ((train_timer % 8) == 7 && rx_dpa_locked_v && !rx_cda_max_sig && {rx_out_sig_i,rx_out_sig_i, rx_out_sig_i,rx_out_sig_i} != 4'h3) rx_channel_data_align_sig <= 1; else rx_channel_data_align_sig <= 0; end train_timer <= train_timer + 1; end endcase end end for (N=1;N<=4;N=N+1) for (M=8*N-8;M<8*N;M=M+1) begin rx_cda_reset_sig = dpa_reset; rx_reset_sig = dpa_reset; rx_dpll_hold_sig = !train; end end - Altera_Forum
do u mean "rx_outclock port" u are using is the slow clk from External Pll or??? because I am using LVDS in External Pll mode. I dont have rx-outclock.
