18 years agoScaling core clock of 100MHz to 23MHz & 20MHz
Hello All, I am using Altera Stratix II for my project. I have generated a PLL in LVDs mode(for a deserialization factor of 10 and date rates is 1000Mbps). The two available clock sources ...
18 years agoI tried with following code to align the word but its not working. I have taken "ready" signal to increment the address of the ram. Could you suggest any modifications?
Data_align : process (iRxClk,inUserReset) -- variable count: integer:=1; begin if(inUserReset='0') then rx_channel_data_align <= "0"; elsif(iRxClk'event and iRxClk='1') then if (rx_channel_data_align = "1") then rx_channel_data_align <= "0"; end if; if(rx_dpa_locked="1") then if (rx_out = "0100110101") then rx_channel_data_align <= "0"; ready<='1'; else rx_channel_data_align <= "1"; end if; end if; end if; end process Data_align;
