18 years agoScaling core clock of 100MHz to 23MHz & 20MHz
Hello All, I am using Altera Stratix II for my project. I have generated a PLL in LVDs mode(for a deserialization factor of 10 and date rates is 1000Mbps). The two available clock sources ...
18 years agoIt's not part of the MegaCore, it's a user design. If I remember right, there have been also Altera design examples with DPA, but I don't remember where I had seen them.
It's not particularly necessary to enable rx_outclock, but I wonder which clock you are using to process your received data. I give you my code as is. It's for a 4x4 multichannel LVDS revceiver. As an additional hint, the dpa_reset[1:4] signal is used as start trigger for train sequence, it is generated by another design component communicating with LVDS sender. 4'h3 is the respective train pattern. always @ (posedge RESET or posedge rx_outclock_sig)
begin
if (RESET)
begin
train_timer <= 8'hff;
train <= 0;
rx_dpa_locked_v <= 0;
ModulFehler <= 4'hf;
end
else
begin
if (dpa_reset)
begin
train_timer <= 0;
train <= dpa_reset;
end
else
begin
case (train_timer)
255:
begin
train <= 0;
rx_channel_data_align_sig <= 0;
for (N=1;N<=4;N=N+1)
if (train)
begin
ModulFehler = 0;
for (M=8*N-8;M<8*N;M=M+1)
if (!rx_dpa_locked_sig || rx_cda_max_sig)
begin
ModulFehler = 1;
end
end
end
default:
begin
if (train)
begin
if ((train_timer % 8) == 7 && rx_dpa_locked_sig)
rx_dpa_locked_v <= 1;
if ((train_timer % 8) == 7 && rx_dpa_locked_v &&
!rx_cda_max_sig &&
{rx_out_sig_i,rx_out_sig_i,
rx_out_sig_i,rx_out_sig_i} != 4'h3)
rx_channel_data_align_sig <= 1;
else
end
train_timer <= train_timer + 1;
end
endcase
end
end
begin
rx_cda_reset_sig = dpa_reset;
rx_reset_sig = dpa_reset;
rx_dpll_hold_sig = !train;
end
end
