17 years ago
Scaling core clock of 100MHz to 23MHz & 20MHz
Hello All,
I am using Altera Stratix II for my project. I have generated a PLL in
LVDs mode(for a deserialization factor of 10 and date rates is 1000Mbps). The two available
clock sources on the board are 100MHz and 62.5MHz. I need to generate 23MHz and 20MHz
MHz clocks for a module in my project.
When I try to generate a PLL in LVDs mode in Mega Core Wizard, by
default it selects a FAST PLL and the minimum output frequency is
33.3333MHz.
Can I use any other logic and generate a 23MHz and 20MHz clock from 100MHz
core clock. Can any one of you suggest a solution to this problem.
Many thanks in advance,
