14 years ago
'Process' way of work
I'm having a problem concerning VHDL understanding of the 'Process' way of work.
Inside the Process, I assigned "idan_input" into "idan_input_buff" (after the "elsif clk'event and clk='1' then").
The signal "idan_input" is changing randomly from the Testbanch but the problem is that "idan_input_buff" signal is changing at the exact same time . How could it be??? According to my knowledge, I would expected to see "idan_input_buff" changing one cycle after "idan_input" has been chained.
RTL confirm that should be one cycle delay due to D.F!
Please help…:confused:
Idan
    you would not burn the testbench to the target. and it should work as you expect
    thank it works.
    but when I'll burn the code on the target, it is possible that the input will rise/fall at the same time as the internal clk. In that case, how can I use:
    " if (Idan_Input_buff = '1' and Idan_Input = '0') then" in order to reacts to falling adge? Both signals will change at the same time, so the code will not executed (Idan_Input_buff = '0' and Idan_Input = '0' ).
    Idan
    a QaD fix is to slightly offset the timing of the input signal by adding e.g. 25 nsec to the times specified.
    Idan_Input <='0', '1' after 1000.025 us,  --(1/700Hz=1428usec,1428usec/2= 714usec, 714usec+1000us=1714usec)
    					   '0' after 1714.025 us,
    					   '1' after 10100.025 us, --(100000*0.1usec=10000mac counter)
    					   '0' after 10814.025 us,
    					   '1' after 11528.025 us,
    					   '0' after 12242.025 us,
    					   '1' after 12956.025 us;	--at lest 14000000 nsec simulation runinig time
    First, thank you very much for your quick response!
    What exactly should I do in order too fix it so I could see the signals in one clock delay cycle?
    I have to fully understand it…
    Idan
    --- Quote Start ---
    because you have assigned Idan_Input using time, rather than making it relative to the clock, what josb said happens - clock and the input rise at the same time, so the process things that Idan_Input has risen before the clock.
    --- Quote End ---
    It is not the 'process' that thinks that the input is one at the time of rising clock but the 'simulator'.
    Both your clock input and signal input rise at the same moment. The RTL simulation sees the clock rising and then checks in zero-delay the state of the signal but this has risen at the same time as the clock and the simulator sees a '1' ...
