14 years ago'Process' way of work
Hi, I'm having a problem concerning VHDL understanding of the 'Process' way of work. Inside the Process, I assigned "idan_input" into "idan_input_buff" (after the "elsif clk'event and clk='1' th...
14 years agothank it works.
but when I'll burn the code on the target, it is possible that the input will rise/fall at the same time as the internal clk. In that case, how can I use: " if (Idan_Input_buff = '1' and Idan_Input = '0') then" in order to reacts to falling adge? Both signals will change at the same time, so the code will not executed (Idan_Input_buff = '0' and Idan_Input = '0' ). Idan
